jtmcinder
DSM Wiseman
- 5,402
- 97
- Nov 4, 2003
Iowa City,
Iowa
OP: a Ferguson AWD (as we have) often has a VC in the center and a VC in the rear for exactly the reason that this thread is focused on: to keep the car from getting stuck. You don't need one in the front, because the front end is heavy, as you already mentioned, yourself.
If all you want is to not get stuck, then just add a rear VC (since that's easy) and be done with it. Note that this is actually better in many cases than a helical or a clutch-pack, since a helical requires some grip on both ends and a modified clutch-pack must be transmitting some torque in order to lock.
Stay away from anything like an insert. They are pure evil.
I don't know if Mr PopUps is being pig-headed or whether his posts match his understanding exactly, but he needs to be ignored. Clearly, slapping doesn't work, so let's just stop replying.
I think that's a good idea and would work but I would have to think about that one...I don't know if I could pull that off in a stylish car
