LSD Insert Breakin
Fmstrat
90
Jan 17, 2003
Apex, North Carolina
Been searching and searching but I can't find the post where I read the answer to this. I just installed an ACT2100, xACT flywheel, and ExtremePSI LSD Insert. I know normally you break in a clutch for 200-300 miles going easy on it. But once I've done that, how do I break in the LSD Insert? I remember reading somewhere on here about launching the car hard 10 times, and I figure doing small circles would probably do it to. Any help? Thanks!
daren_p said:
Im not sure you do have to break in a lsd insert? I know you need to break in the kaaz lsd by doing figure 8's, but this is a true clutch-type differential, not just an insert.
Right. There is nothing to break in with these inserts. It's basically just metal rubbing on metal; although, there are a few inserts that use a clutch-type friction material, but you don't have that type.
good luck with that insert, mine didnt last too long. My diff that is.
