Rear drive shaft...
craziloki
109
May 13, 2009
York, Pennsylvania
So what is the best way (easiest) for removing the back drive shaft for engine/trans removal? :D
Are you trying to remove the engine and tranny or just the driveshaft? I've never pulled the engine or trans with the T-case still attached. It's 5 bolts, not that hard to do, I'd say <30min max. Its also a good time to fix the yoke leak, if you have that problem.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
