Rear diff rebuild info? Bolt torque, backlash etc.
Ben-Stian
131
30
Aug 23, 2006
NORWAY, Europe
Hi,
Anyone have the factory manual on this subject? I have seen it years ago, but cant find it anymore...
Thanks
Nice find! That is a great picture thread. With that link, as well as the factory service manual I just provided you should be set to have all the data you need.
For added fun, here is the factory part numbers for rear differential rebuild parts from my spreadsheets. As well an attached image from ASA of the rear differential exploded diagram with part look up codes (not the part numbers; those are listed below).
Part Description Part Number Quantity
Rear Differential Side Tapered Roller Bearings MN168441 x2 -- Bearing Part Number: HR30207J
Pinion Inner Bearing MB393956 x1-- Bearing Part Number: HR32207C
Pinion Outer Bearing MB393955 x1-- Bearing Part Number: HR30305C
Rear Differerntial Side Seals MD707184 x2
Rear Differential End Seal MB393929 x1
Shim Set B MB185360 x1
Shim Set C MB185350 x1
Shim Set D MB241903 x1
Fill Plug and Gasket MB001261 x1
Drain Plug and Washer MB569390 x1
Rear Diff End Nut MA143517 x1
Rear Differential Cover Bolts MF244882 x8
Rear Differential Cover Breather Bulb MB393530 x1
Driveshaft Connecting Flange MB393977 x1
Ring and Pinion Gearset MB185307 x1
LSD Case Machine Screws MB290419 x4
Ring Gear Bolts MB092220 x8
TRE Evo LSD Clutch Type Ninja Diff Cover Bearing MD710663 x1
Great info! Thanks guys:)
