1G Rear calipers for my 90' AWD
1g_talon_awd
Mar 8, 2022
Ravensburg, Europe
Hello, I'm searching for rebuild rear calipers for my 90' Talon AWD.
Now I searche many hours to get a pair, but then I recognized, that there exists different types.
First I was sure, that I found the correct parts which have a bore size of 30.099.
So then I found this caliper, which should be suitable to cars after 92' with a bore size of 34.798.
So if it would fit, I would like to swap to the bigger ones.
Does anybody know if this later caliper would fit to my 90' AWD?
Here are two links to the calipers I found:
And if anybody know a dealer where I could buy this shipped to Germany, would be great.
Thanks!
I see you are in Ravensburg De. Nice area, visited a few times.
However, RTM has a rebuild service for 90' AWD DSM calipers. They should be able to send you a rebuilt set with a core charge until you send yours back. Shipping may make this not worth it though.
Link to 1g caliper page:
Going to the larger bore size in the rear will reduce rear braking force unless you also switch the proportioning valve. If the fronts are different bore sizes between a 90' and 92' you may need to change everything.
Thank you for your answer!
Yes Ravensburg is a nice place to be, here near to the lake of constance.
I want to go to a bigger size in the rear, because I want to upgrade also the front to the Outlander brakes. Maybe I need a proportioning valve yes.
Do you know if the rear can be switched to the bigger ones?
