edged1g
- 302
- 25
- Feb 23, 2005
Huntingdon Valley,
Pennsylvania
I may have a huge part out coming
You won't part it! It's an addiction! JK...good luck man.
Oil drainback will be impeded by any pressure, even atmospheric. For proper windage and drainage a crankcase must be under vacuum. Otherwise the oil wont drain properly no matter how many drains you add.
The oil drain holes in the head provide plenty of area for the vacuum to draw on the entire crankcase. Take a V8 for example which has two, small drains around 1/2-9/16". Using a standard PCV system we can draw 2-4 in/Hg vacuum. Add a vacuum pump and we can easily draw 10-12 in/Hg. The 4G has more drains and they're larger diameter so to say they're insufficient to pull enough vacuum on the crankcase is not an accurate statement.
If you cannot draw at least a couple inches of vacuum on an engine using a conventional PCV system then there is a problem. I'd be looking for cracked or leaking PCV lines and fittings. Additionally, any gasket or seal on the engine that is leaking will allow air to flow in and reduce vacuum. The rear main seal, oil pan and valve cover are the most common areas for this to happen.
Well, off topic and ill be starting a thread in a more populated area but the machinist that was known and proven to be good around here is retiring. Im at a standstill til i get a good machinist. Heading to newbie section as the regional st louis area section is deader than a doornail.
I would prefer the back or top of the rear BS hump for a vent, as long as there is enough room to work on/remove the starter. The crank sprays oil as it spins, but the oil leaves mostly in a tangential direction clockwise when looking at the front of the engine. The top of the rear BS hump would be in a location to receive a bit less oil then the top of the front hump. Also, I have thought about using the front bs shaft hole in the front cover as a vent. The plus is that it's a large opening but a minus is that it's at the front of the engine (front cover). The baffle would be hard to implement. The timing belt cover would have to be modified and I'm paranoid about stuff getting in the cover. Also, if there is an oil leak into the cover the timing belt may be compromised. Also, the accessory belts would be in the mix as well. A belt change may require the fitting to be disconnected and then reconnected. I'm getting old and forgetful and would probably drive off with the vent hose disconnected.
I believe in KISS principle. Help the end user minimize the chance of making a mistake.
The BS check bolt location would be great for measuring the crankcase pressure(dipstick tube would be another).
I ramble too much.
FedEx will carry a block from you to me at a reasonable rate
But like I said earlier, and perhaps I didn't properly articulate my point, the oil drains in all of the 4G engines are more than sufficient to allow efficient oil drainage back to the sump. Positive pressure in the crankcase will impede this flow. If you've got an engine in which the oil isn't draining back properly then I would be willing to bet good money that you've got excessive crankcase pressure. It doesn't matter if you've got one small drain port or a hundred giant ones- excess pressure will stop the oil from draining properly and it will build up in the cylinder head.
I cant 100% agree with this. .
! Just got another IRS letter today, these guys smell blood. I pay so so much in taxes yet its never enough. Was gonna write a check for a new car thursday, looks like the Lincoln is gonna get some more work mileage for a few more months!Here is how I have mine setup. I ran a 1/2 npt 3/4 barb to intercept the factory vent port from the block and the same on the balance shaft inspection hole. The only difference is on the balance shaft inspection hole I tubed the fitting to enter the block about 2 inches this mimmick the factory pcv valve installed in the valve cover and it keeps oil from entering the catch can and there is no need for any type of baffling. I create vacuum via the turbo inlet pipe via a mishimoto sealed catch can and the 6266 does a nice job pulling the vapors out of the block . This way I have a nice clean look on the valve cover side and adequate vents on the bottom. The main reason i did this is to keep the crank pressure from hindering my turbo oil drain flow back to the pan and my oil drain flow from the head back to the pan.I understand wanting to ventilate the pressure, but how do you plan to pull a vacuum on the crankcase? A passive system of just venting to atmosphere is not a good idea.
Valve cover is stock unmodified. I have the two valve cover holes going to a second breather catch can my thinking is a source of fresh air under boost as bottom end vacuums. When I finish my transmission I am going to log valve cover pressure to see just how much vacuum is being created.With this setup, did you remove the factory PCV and the vent on the VC and block them? Any pics of the VC?
Great stuff man. Since it will be a challenge for me to get to that area of the block since the motor is in the car I think I will just get the vented dipstick holder we discussed ,run a -6 line from the -6an fitting it comes with and place it to my other catchcan which is vented. I think your way is the preferred way to go though especially since you have the block out. Nice how you have the top plug going to the vent that leads to the head.Valve cover is stock unmodified. I have the two valve cover holes going to a second breather catch can my thinking is a source of fresh air under boost as bottom end vacuums. When I finish my transmission I am going to log valve cover pressure to see just how much vacuum is being created.
I see you have the raceshaft in there too kelsHere is what you want. The factory pcv effect. I would like to make a correction don't use the Bs inspection bolt hole it sits to close to the roof of the area cast for the balance shaft and will allow oil to enter the tube. It's important that the tube be suspended in mid air to capture only crank case vapors not oil. Here's a picture of mine.You must be logged in to view this image or video.You must be logged in to view this image or video.
