really lean; problems
Antman2185
Jun 21, 2002
Vienna, Virginia
My car goes really lean at light throttle. Immediately after going from say < 5% throttle to around 17-20% throttle, my AFR goes lean. My o2 gauge stays red for a bit then gets normal. Logging my AFR w/ dsmlink it says 18:1. I can not seem to change it. When it hits really lean the car does not seem to accelerate, it lags. I don't know what wrong.
I was looking and I believe I have an air leak between the turbo and exhaust manifold. I could feel air coming out and my heat shield was all black in just that corner. Could this be the cause of my problem?
Thanks,
Anthony
It's lagging probably because you're knocking so much that the ECU is severely retarding your timing.
Did you check for boost/intake leaks? What about the condition of your fuel system, pump, filter, regulator, etc?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
