real quick timing question
jongreene
484
6
Nov 3, 2005
midland, Michigan
Stupid question....Theres 3 notches as to where your timing can be. It goes notch, #10, then another notch, and then the TDC mark. My timing is resting on the notch after #10 before the TDC mark.
On a logger my timing read -2 ,so which notch should my mark be resting on? the 1st , the #10 or the third notch?
Are you talking about on the crank? ... there should be only one place for it to line up... do you have a 6-bolt or a 7?
And this may be a stupid question but your adjusting timing with the car running and the logger disconnected and the harness grounded correct?
The 0 mark represents TDC... The marks are either 1* or 2* increments... can't remember off hand. But you want the white mark to float at the -5* mark on the timing plate.
