Re-located the Coilpack
1gdsmraider
195
Sep 13, 2004
Ann Arbor, Michigan
After installing a new AFPR I realized I had to remedy the lack of space for the wires.. This is what I ended up with.. :rocks:
I couldn't decide if I should put this here or in Off-Topic.. so hope I got it right :p Oh and Ignore the beautiful zebra pattern.. the previous owner had a very cheap spray job done and I haven't gotten around to fixing it.
Re-route/organize your wires, avoid crossing them if possible, use the stock spacers and brackets.
http://www.pepboys.com/learning_center/car_care/articles/svc_ignition.html
5. Replace the spark plug wires: It is a good idea to replace the wires that connect your spark plugs to the distributor cap at this point as well. Take each wire off one at a time, and match its length with the new wire from the replacement set. Before putting the new wire on put some dialectric grease on the end of each spark plug to prevent corrosion. Make sure to route each wire exactly the same way as the old wire. Replace any wire looms or separators if broken. Criss-crossing wires can cause cross-fire or arcing which makes your engine run rough.
