RC Injectors o-rings replacement
b15turbo
71
Feb 1, 2006
Columbia, South Carolina
I got 550cc RC injectors and i did a boots leak and one of them is leaking really bad i wanted to know where i can get the new o-rings for them, do i have to buy specially for the RC injectors or can i use the stock o-rings???
Since you say that they are leaking during a boost lesk test I assume ot's the injector insulator that is bad and that air is leaking out around them and the injector pintle.
The RC 550cc injectors use the stock injector insulator, sheet and o-ring.
That actual part numbers of each are in the archives. http://www.dsmtuners.com/forums/showthread.php?t=133819
Steve
