RC Engineering 550cc injectors PL8-550 need o rings and seals right?
topdownturbo
Apr 8, 2012
Joppa, Maryland
Ok,
Just picked up a used set of RC 550cc injectors. They didnt come with O rings or seals so what kit should I get? I was checking out Extreme PSI for O rings and found a "rebuild kit" Precision T&E Injector Rebuild Kit: SCIM 550cc Disc Style Injectors #21517.
Can I use this kit since I dont have seals or is this kit to rebuild the actual injectors and all i need is an O ring set?
From the research I have done these injectors will work without any ECU mods or an AFPR. I do have an AFPR that I have not installed yet though.
I checked the resistance on each injector to see if the coils were still good and they measure 2.2 Ohms which is perfect according to the specs from RC.
So if someone could just let me know the best kit for new seals to use on RC injectors that would be awesome!
Ok. So I can just get some replacement O rings at the parts store? Should I reuse my lower seals or get some from the dealer or aftermarket?
Got new lower seals and O rings from the dealership yesterday. After getting raped for $32 and some change I hope they are worth it. Probably gonna slap the injectors in this week.
