random misfire please help!
jimmkaz
Oct 1, 2012
Buffalo, New York
ok so i have a 91 eclipse with the 2.0 n/t manual, i keep having a misfire issue with it ive tried everything and have had no luck. when i got the car it was throwing codes for cam sensor, coolant temp sensor, maf, and tps. ive changed all of them and the codes are gone but the car still runs like hell, im using the ngk br6es plugs have brand new wires and coil. the exhaust reeks of gas and it seems like the car is getting way too much, the fuel pressure tested to 38 psi which from everything ive read seems good, the spark is solid and blue, timing is good... idk what else to check i've metered all the sensors i've changed out and they are all falling within spec... any ideas anyone?
