Random High RPM Misfire
hisandherturbo
118
Jul 27, 2005
colorado springs, Colorado
I am trying to chase down a misfire that is driving me crazy. It's not all the time, but most of the time, it happens about 30% of the time I try 1st, 60% of the time I try 2nd, and 90% 3rd. Anyway, Tried 3 different sets of new plugs gapped between .20 and .26 (BR7ES, BR8ES, BPR7ES). swapped 3 different coils packs, 2 sets of good wires, and none of the above even make it act different. The only time it's different is when I go from stock ignition to either my MSD-DIS-2 or a brand new ARC-2........ and with the stock ignition it's actually not as "ruff" or as often. YES It's WORSE with a CDI, more often and misses "harder". The only thing I noticed that I am not sure if it's right or not is my lower voltage at the coild pack itself (almost .5v lower then every where else).
TY
JOE
what wires you running, what boost, how much tiimng? I had an issue that was like that, wires wouldn't last a week till i got magnecores, they solved it and lasted years..those crap accell wires woudl blow out in 3 days tops
Magnacore's, newest set is less then a week old
I can't go below 28psi with my setup
E85
Stock timing maps
Transistor connections were corroded.......
Quick question - What/where are those Transistor connections you found that were corroded?
Only because once in a while my car will misfire and buck when cruising normally and I'm thinking those could be something to check out; and hopefully solve my problem before replacing plugs and wires.
Thanks
