quick question about tuning 680s..
blcknspo0ln
DSM Wiseman
7,772
102
Jul 31, 2003
Central, New Jersey
I hate to ask but I HAVE to ask before I drop my 680's in. real n00b question but can anyone verify the actual process I will be going through to tune these things? throttle points are 30/80
1. set short term and long term trims to 0 at 1k, 2k, and 3k
2. bring 3k settings across the board to 7.5k
3. set HI throttle corrections.
4. do a 3rd gear pull
5. adjust where needed
I've read and re-read almost every SAFC tuning thread here but I can't pick apart the important and RIGHT info... and I also don't have a wideband, i'll only be looking at logs.
I'm just wondering if this is the right steps because I dont want to put the injectors in and a: run too rich and kill timing or b: run too lean, kill timing, and blow my motor.. any suggestions are appreciated.
oh yea, just to add: my MBC was set to 16 psi and is now set to 14 psi but creeps to 18 psi. safe to say I can't set a base boost pressure at say 15 psi and tune and raise boost from there.. I'll have to be tuning 18 psi from the get go. anyone have a safe setting to provide enough fuel for 18 psi and virtually no idea how the logs look?
awesome.. good to hear, thanks.
i'll post logs and results sometime next week, the car is going under some minor changes and will be on jackstands for a couple days :) wait, car on jackstands usually gets a :toobad: smiley.. haha
-25 worked very well. thanks for the good number to start with. i'm starting to lean it out more [at -29 right now, still tuning] and am getting about .97 V with 16* peak timing. hopefully I can lean it out a bit more and bump up the timing though.
HI - 1k 2k 3k 4k 5k 6k 7k
-27 -27 -27 -29-29-29-29
