Quick question about timing belt/water pump install
LifIsPeachy02
362
Mar 3, 2003
Middletown, Ohio
Ok, i just did my timing belt and water pump...took me about 2 days but i did get it finally.
My question is...should i give the belt and pump a break-in period before running it kinda hard??
:laugh: It took me 2 days also when I did mine because I just threw all the bolts in one pile and forgot wich ones went where. I didn't give any break in time on mine but I don't know if you are supose to. Nothing bad has happened yet. Knock on wood.
LOL i know how that goes...most of mine were scattered through out the garage. I had a few left over where i was just like eh, u don't need that one its sturdy enough. i took about a 2 hour break saturday and friday i only worked for probably about 4 hours. So in all it took about 10 hours.
Damn atleast i'm not the only one with that problem. I had 1 freakin bolt left over when i did my timing belt and water pump. It was a pretty damn big bolt too but i honestly could not find where it went at all!!! Looked for 2 stright hours and stil couldn't find where it went. Everything seemed sturdy and fine so it was fine with me. 6,000 miles later and still no problems. By the way i drove it like i would normally after i did the install, you don't need a break in period. It's not a new motor just a new belt.
It's my opinion that you having the sense to think of this is indication that you'll give it enough consideration to let it get comfy before really USING it.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
