Question about water pump and timing belt.
dyno_detour
990
4
Jul 14, 2005
Mason City, Iowa
I have to get my water pump and timing belt replaced. The mechanics quoted the repair between $600-$700 labor included. Does this sound right or am I getting ripped off? Thanks
The local Mitsu shop here chrges $350 for the timing, not too sure how much the water pump would be, but that does sound high.
Mike
That is a pretty high quote on parts/labor even if they replace all the pulleys (3), tensioner, seals (5), bb, tb, and wp. As stated, 95% of the labor is getting to the tb. If it is just a tb, bb, tensioner job that is rediculous. Buy all the mentioned parts, find a buddy to help, and save yourself half of that. Plus you learn something along the way.
Jim
Jim
actually.. price break down is like this (i should know, I just did it)
tbelt - 85
autotensioner - 100
waterpump -130
pulleys - 100
Bbelt - 45
so it adds up.. but then again, this is all OEM stuff from the stealership
tbelt - 85
autotensioner - 100
waterpump -130
pulleys - 100
Bbelt - 45
Oops, your right. I meant to say UNLESS they replace everything. Just a standard tb, bb, tensioner, wp job is high at $6-700. Anyway, if you do the work yourself, you can replace everything for quit a bit less.
Jim
