quick exhaust manifold question
foxracing4500
336
9
Jan 21, 2012
Europe
buying this really soon but I wanted to find out who made the exhaust manifold, also
looks very identical to the T3/T4 but its not,
Exhaust Manifold
also it has two wastegates :confused:
HAFE cast manifold.
^ You can't see it still attached to the turbo? Is the flapper welded shut, or flapper just un hooked from a boost source? If that is the case, it will just blow open.
it does have an internal wastegate but I need opinions, if I kept the internal would I have to deal with boost creep? Because I am really thinking of just welding it off (internal) when I get it.
If youre getting the external with the setup in the picture then just go with that and weld the internal shut.
