Questions
maxddr19
141
Mar 12, 2012
Martin, Tennessee
My speaker isn't working in the back on the right side and I have no idea what's wrong with it. They are all stock so they haven't been replaced. Is there anyway i could see what the problem is so I can fix it? And my other problems is I have a some stains on the backseats and I didn't know of any products that will remove them. I was thinking oxyclean. Something around those lines. Any suggestions?
With the speaker you could pull it out and plug it into the other side if it works then it's a wiring problem and if not well the speaker is junk, as for stains I'm sorry but I havent got much for you there, probably oxycloean or some resolve carpet stain remover and some elbow grease will work best, good luck!
Quick Trick for the speakers - Take a few lengths of wire and run them to the speaker. From the other end, take a AA battery and rub one wire on the Positive side, and the other wire to the Negative. Rub the exposed wire gently against both sides of the battery. If it makes noise, it at least works. This is commonly used to locate which color wires lead to which speaker in vehicles if you don't have a diagram of the wire colors.
