Questions eagle talon cl 93 fwd
alltheway2drag
76
Jan 8, 2012
Trois-rivieres, QC, Canada
Hi i would like to know what motors fit in my eagle talon 93 cl please.
I broked my block.
so im looking for a block or the whole motor ... and i want to know all the motors i can put in .. thankx a bunch
The ES was the NT 4G63. Just pick up a 4G63 block or entire engine and drop it in. Matching year would be preferred - stay away from the 90's as there are modest differences here and there.
Just for the record.
ok , but does any mitsubish eclipe motor fit in ? like example de eclipse 99 GT 24 valve model...
and do you know where i can find some blocks .. or even the whole motor .. thankx
:rolleyes:No...the v6 does not fit...if you want fast, the 4g63t will eat the v6 and shit it out.
:ohdamn:and the 4g63 is the same motor that was in an eclipse of the same year...
along with the 1.8 There is alot of good information on this forum to be had. If your going to be a DSM owner, I would study hard. Welcome to DSMtuners!
4g63t specs ... whats that motor ? in what eagle was it ? or mitsu
Mitsubishi 4G63T Engine JDM
Displacement (cc):
2L
Horse Power:
210 HP
Torque (ft/lbs@rpm):
214 @ 3,000 rpm
Compression Ratio:
8.5:1
Valve Train
DOHC 16 valves
24 cyl.
JDM Transmission
AWD
Mine is a FWD still fits in ? and would that be even better with a higher compression ? i mean fast (with a higher compression)
and where can i find thos ?
With the questions asked, the OP is not ready for a turbo DSM, muchless the work needed to perform the swap.
All you need to do is look for a 91-94 4G63 Non turbo engine and drop it in - do the research and perform any needed steps to perform the installation successfully. 90's will work, but again.. there are subtle differences. It appears you have tons of room left to grow in knowledge. Don't go trying to bite off more than you can chew.
Engines are easy to come by, found a few at the local junk yard, years ago, when dsms were easy to find back in the day.
It was in eclipse gst/gsx, talon tsi fwd/awd and galant vr4 in the us. No such animal as a JDM eclipse or talon my friend... in a turbo car.....forget it. If your going to do ANY kind of work or even think of messing with a turbo car, do about 3 months worth of reading on here
