SpooledGSX98
- 934
- 1
- Feb 3, 2003
Phoenix,
Arizona
I'm starting to piece a turbo kit together, mostly in my head, and I need to find out where to get parts from, what manifolds work, what turbos to look into, etc. As for the parameters for what kind of street set up I want, I'm looking for a pump gas, daily driver, stock internals (maybe cams at the most). And I dont want to be pushing the stock block to its limits, I want it to be reliable. A lot of the parts Ive been thinking about, Ive heard stories of those certain manifolds cracking, etc... I know this is a pretty bland thread, but I just need to know what parts I should stay away from due to quality, and if this seems like a very possible/practical setup, etc (also, please no vendor bashing)
Heres whats been going through my mind recently:
RS49
The next step and the most popular street/strip T3/T4 hybrid combination. Our vehicles have been able to reach 20psi of boost at 3700-3800rpm. We have been able to reach over 400whp on pump gas with this turbo.
-49 lb/min compressor
-50 trim T04E compressor
-76 trim T31 turbine wheel (stage 3)
-T04E (3" inlet, 2" outlet) polished compressor housing
-Setup for manifold mounted or O2 mounted external wastegate
(internal wastegate optional)
Better Cooling
Weight Saving
Stainless Steel Wont Rust
Say Good Bye To Cracking
Smooth SS Piping
No Porting Needed
External wastegate flange to help the turbo to spool up faster! The Tial 40 is a tried and true wastegate combination that will keep your boost levels in check!
This kit includes
- High flow exhaust manifold. Will fits Garrett T3/T4 , and any turbo with Garrett T3 flange
-This manifold is for use with a Tial 40mm. external wastegate or equivalent (For off road use only)
-TiAl 40mm wastegate
-Turbo XS standard BC
-Walbro 255lph fuel pump
- PTE 680CC DSM Ball and Seat Injectors
-ACT 2600 Clutch Kit
-7 Bolt, Fidanza lightweight flywheel
-Made from a new 28"wide x 10.8"hi x 3"thk side to side flow core. End tanks are 1/8" thk aluminum. Inlet and outlet are 2 1/2"dia. beaded tube.
(Intercooler piping will be fabricated by MetalManFab, same guy that did MLopez's AWD Spyder).
-Fluidyne aluminum radiator
-12" Slimline fan (flows upwards of 1360cfm)
Like I said, this is just a rough draft, and not a wishlist. I already have a Apex-i SAFCII, and a HKS turbo timer waiting to be installed. Any help in which parts to stay away from, what i should add, or what i should definitely go with will be greatly appreciated.
RS49
Better Cooling
Weight Saving
Smooth SS Piping
No Porting Needed
This kit includes
The deal with the SAFC, I bought it from my buddy, pretty good deal, couldnt pass it up. But I should look into DSMlink, didnt even think about it. An FPR was another thing on my mind, but seeing is how majority of you mentioned it, looks like I am gonna add it, any recommendations? Now as far as cams, definetly HKS. Would 272°/272° be too big? I dont mind a nasty idle. But I hear big duration + big turbo = good.
. i personally think you should get a centerforce clutch. I heard that the pressure from ACTs clutch help to induce crank walk.
I'll do some research. Another thing I heard about the ACT2600, when it comes to inducing crankwalk...I heard if you disable the clutch pedal safety switch to where you can start the car without having to disengage the clutch, CW shouldn't show its face. Can any of you other guys give some input on clutches? Thanks
