Question on bleeding caliper
alltheway2drag
76
Jan 8, 2012
Trois-rivieres, QC, Canada
Hi , my brake (right) hose broke today so changed that.
When it was time to bleed my brake , saw that the 2 front sides bleeding notes were broken into the caliper.
SO MY QUESTION IS
can i bleed the brakes a different way ?
tried to bleed them from the hose stuck to the caliper , didnt work.
PLEASE HELP ME !
It will he pretty hard to get all the air out without being able to use the bleeders. Sounds like it is time for some new calipers.
You have to use the bleeder screw that is attached to the caliper. You have to force out the air thru the bleeder nipple until solid fluid squirts out. If the nipples are broken you have to replace them otherwise its a no go situation your in until you get them fixed.
