question on battery relocation
some type of fusable link, a breaker switch if you will. In the event of a car crash your car could catch on fire if the 2gauge hot wire was smahed between wrinkle metal arkin and poppin off. For what its worth, yes, you need it.
Also, when you run the power wire up to the front of the car, also run a ground wire up to the front as well. From the negative battery post in the trunk, run a ground wire up to he engine and ground at the bell-housing. Dont rely on trunk-mounted grounds only.
