Question about SS brake lines I bought from Buschur
vr6chris
149
4
Jan 1, 2004
Silver Spring, Maryland
Ok, I ordered a set of SS brake lines for my 90 AWD Talon. I recieved them today, but there are only 4 lines. I thought 1g had 8 because they disconnected at the strut. But I called buschur and talked to someone there and they said that the awd 1g had only 4 but the 1g fwd had 8. Is there any truth in this. I need to install these, but dont want to open it, if its the incorrect parts.
well, two are fairly short than the other 2 are a little longer. ill take a pic to show you guys what im talking about
if these are correct, which i assume they are. which go to the front and which to the rear?
I'm still not sure you have the right kit, or if your kit only replaces 4 of the 8 OEM rubber hoses as on Buschur's site the picture of the 1G set shows 8 Lines :confused:
May also want to check some of these past posts on SS Brake lines as might help:
http://www.dsmtuners.com/forums/showthread.php?t=193511&highlight=brake+line
http://www.dsmtuners.com/forums/showthread.php?t=143864&highlight=brake+line
http://www.dsmtuners.com/forums/showthread.php?t=138763&highlight=brake+line
1) Don't bump your posts and 2) like someone else said, call them and find out. Everyone is telling you there are 8 lines, you only got 4 of them. So call them and talk to them and find out why there website shows 8 lines yet you didn't get them all. It's really not that difficult. :rolleyes:
