2G Question about rotor size and caliper position
PieEyedPiper
DSM Wiseman
5,580
65
Nov 13, 2004
North Bay Area, California
Check out this thread for the details: http://www.dsmtuners.com/forums/showthread.php?t=197866
I'm trying to find out if anyone can answer my question, if so please post in the thread above.
PieEyedPiper said:
Also, if these rotors are 303mm (read: bigger than ours) and we use the stock mounts with the XG caliper, or even our own calipers (despite any required modding), would that not defeat the purpose of larger rotors?
If I understand correctly, you have greater braking power with a larger rotor due to leverage, right?
But what happens if our caliper is grabbing at the same height on the larger rotor as it would on the stock ones? would it effectively give us the same breaking ability since its not using the enhanced diameter of the new rotors?
maybe I'm over-analyzing.
Yes, greater diameter = greater leverage = more braking power.
That story you linked to seems a little over-simplified. The Tiburon rotors may fit but there's more custom work involved than he told us about. Unless you can do the customization yourself, you may not save anything over a bolt-on kit.
Leave width and thermal capacity out of it. That has nothing to do with 'power' which really is torque in the proper term.
Larger rotor will increase torque. BUT....that's only part of the equation.
You'd really need to know the piston area of both calipers (old and new) to speak total torque or 'more power'.
If the new caliper has less piston area, even on a larger rotor (assuming same pad compounds in both) you may actually lose torque. And just because you put on the larger rotor that in itself won't make the car stop quicker. More diameter simply means the pistons don't have to bite as hard (i.e. lower line pressure required) to do the same job. They are not really making more 'power' they are simply changing the way it's done.
On the final hand, if the rotors are larger and the total piston area is greater then the whole combo can produce more total torque then the previous set up. At far less line pressure. Sounds good huh? But it comes at a price; poor pedal feel and loss of rear brake bias.
wret, i think you're crossing the two upgrades listed in that thread. There is no modding other than slight grinding to make it all fit... at least as far as I could tell.
I've taken into account all the info presented in both these threads and I've concluded that "upgrade" isnt much of an upgrade due to the "lack of torque" gained. Without that extra leverage, there cant be much greater braking power other than that from larger heat capacity etc. Also, as pointed out, piston surface area would be a key element.
unless that caliper from the XG is grabbing the rotor higher up than our stock calipers would, this isn't much of an upgrade at all.
Can anyone verify this?
Give me the exact specifics and I can spit out the bias numbers completely.
Rotor size of each.
Piston size (s) of each.
We'll assume the same pads.
PADS: yes if one of the pads is taller and skinnier than the other you have shifted the Effective Radius of the pad. That will change the torque value. Most street pads tend to be about 2.25" wide so they are not as stout as the narrower 1.75 of aftermarket caliper pads.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
