Question about PCV valve replacement
LRD
Jun 1, 2012
Houston, Texas
I just went to autozone to buy a PCV valvle to replace the leaky one in the car and it wouldnt tighten all the way to the valve cover. Yes it is the correct part number. Is the fitment just bad from autozone or is it possible that different valve covers (hyundai JDM etc) take different pcv valves? :confused:
I'll be buying a new part from the dealership next week but just want to make sure that one will actually fit LOL
on a related note... does anyone know if the check valves go bad? I'm still seeing -10 vac and I'm thinking there might be more leaks
PCV valves have tapered threads to create a seal to the valve cover, that's perfectly normal. I worry when it does tighten all the way! As for the low vac reading, the easiest way to find leaks is with a boost leak tester. Do a quick search here or on VFAQ.com and you'll find plenty of info on how to make it and and use it. :thumb:
It literally falls out though where as the old one will actually tighten and stay bolted down :confused:
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
