question about new crankshafts
KaLo_o
227
Mar 9, 2009
Quebec, QC, Canada
i just have a simple no0b question about new crankshafts.... when i look on extremepsi or anywhere else for a crank... there is a mesurment in MM for that crank...like 88mm, 94mm, 100mm Etc.... can somebody tell me what this measurement is exactly?
88mm is a stock stroke length for a 4G63 2.0L
94mm is used to create a 2.2L 4G engine
100mm is a stock stroke length for a 4G64/G4CS 2.4L, and is used to make a 2.3L stroker when used inside a 4G63 block
Stroke is the distance that the piston travels up and down in the bore. The crankshaft's rod journal centers are a distance of 1/2 the stroke from the center of the main journals.
