Question about my spark plugs
99RedGs
520
7
Jun 28, 2007
Somewhere, Wisconsin
I know questions like these get asked alot, but I am not really sure how to word my questions for proper searching.
Ok, I guess I never have really paid attention/ have seen exactly what the proper color of a spark plug burn looks like. I know it is a tan color, so to me these look bad (whitish grey). Also, now that I think about it I don't remember seeing spark plugs with this brown color on the ceramic. I also noticed a slight discoloration on my new spark plug wires (standard replacement 7mm wires).
So these are my questions:
- Does it look like I'm running lean?
- Is the ceramic supposed to turn brown?
- What could cause my wires to discolor?
Thanks
The plugs are around 8,000 mi I believe. You are referring to the 420a correct? Just making sure because some people forget the 2gnt'ers post here too LOL.
I just don't want my dd blowing up on me and I guess I've never really seen the ceramic turn brown before so I was worried there, which made me think the plugs looked like the car was running lean so I was probably just overreacting to something I hadn't seen before.
It has been a while since I listened to my engine and I noticed there was a bit more sound from the fuel rail area than I remember so that also made me worry. I tried taking a video, but then remembered my camera doesn't record sound LOL.
All of the fuel injected catalyst cars spend most of their time trying to run 14:7:1 for emisions.
I don't know if the 420a runs as hot as the 4G63 does but I don't see a problem with how those plugs look other than the rings at the base of the insulators. I can't tell if it's rust, cooked oil, or what.
I'd just get a fresh set and check the gaps before installing them.
Reading plugs pretty-much went out with carburetors.
Looks like your plug boots are rotting. Do you use a lube on them, or has anyone else? The green on the plug base looks like corrosion or soap. Do you wash your engine?
