Question about motor swap??
Gamble97
2,642
63
Jan 3, 2006
small town, Illinois
I have a 97 eclipse that I'm doing a motor swap on. I am building another 7 bolt motor. The motor that I'm swapping is from a 95.
I know there is a difference between the CAS sensors.
So am I going to need a different wiring harness? Or will everything plug directly in?
Just use your intake cam from the '97 and the CAS and you will be fine.
Mike
Gamble97 said:
But doesn't the head from a 97 have the sensor on it and the head from a 95 doesn't?
The '95/'96 have a cam and crank sensor on the timing side of the motor, and the '97 has it back on the pass. side. If you use the '97 CAS, you will just need to put the '97 intake cam in as it has the threads in the end for the '97 CAS to bolt on to. Then it just plugs into your existing harness.
Mike
