420A question about interchangable neon parts
eclipse13
925
Jan 5, 2003
wilmington, North Carolina
A lady friend of mine needs a new alternator for her 95 neon DOHC. Does anyone know if these alternators will work?
*EDIT*
By 'these' I mean a 2g n/t alternator
not sure but I know a way to find out.... go to Autozone.com and look up an alternator for one of the cars and right down the part #. Then look up the other cars alternator and see if the part #s are the same. If so you should be fine. I did this for a different car I used to own and it worked fine. :thumb:
It will work, but I am unsure if it will bolt up to the brackets correctly. Might need a small modification. Do the autozone part # things, thats the best way I have used.
Any one no if a 95 neon power stearing pump and lines will fit the eclipse
