Question about clicking noise when i shift
kdoggx2o00
54
Jul 27, 2004
New York, New York
Hey guys, my 99 eclipse is my first car that i've driven stick with. I noticed that sometimes when i shift gears i hear a clicking sound when my window is down that comes as soon as i press in the clutch. Now this usually only happens when i have a urge to get on it and shift a little faster than usual, or when i don't gas it enough and my car bucks or shakes a little, at which point i hear the same shakey/clicky sound. It doesn't sound bad, but I'm new and im not exactly sure what it is. Is it normal?
Thanks guys
Check your bell housing for cracks. Might be a throwout bearing, Does your clutch disengage at the floor or sometimes you have to double clutch to get it in gear? If so then I suggest check the tranny and check the Throw out bearing. It will save your tranny in the long run.
Defiant said:
Throw out bearing, bent pressure plate finger, loose bellhousing dust cover, bit of smacked skunk wrapped around axle, failing CV joint, or something else altogether.
i think its likely its hte loose bellhousing cover because it sounds like a loose rattle or shaking. The same noise also comes when i turn off the car and the car does the little rumble down, it sounds like a small rattling or shaking as if something is loose.
Any instructions on how to check this cover?
Thanks to everyone for help
sounds like a bad catalytic converter to me... my van had a sound kinda like that (cept it's automatic...) and the cat had gone bad and was rattling around in the housing.
