1G question about air - fuel ratio
OwninFools
71
Mar 15, 2007
Oshawa,
So basically, I have a 94 Eagle Talon TSi AWD. Turbo is running 10 pounds of boost.
When I bought the car it came with a 2G MAF, now there in lies my question!
Now I'm only running the stock injectors, so, I was wondering would an SAFC, SAFC-II or an SAFC-Neo help me to rich it out, without having to change my stock injectors?
And which one should I go with, regular SAFC, SAFC-II or the SAFC-Neo? Will they all work? and will the SAFC be all I need to compensate for the extra air being sent in through the 2G MAF??
And that will do the job to make up for the air / fuel ratio with the 2G maf? I wont need anything else?
They all do the same thing. They'll all work.
All you're doing is adjusting the airflow signal to the ECU.
They will all work just fine but the SAFC-II has a setting for 2 maps were the SAFC-I and the Neo only has 1.
I would also get a wbo2 or bring it to the dyno to have it tuned after you buy the safc. Dont boost it right now because its causing you to run real lean, if you have a stock 1g maf I would put that back in for now.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
