Pulsing lights EVERYWHERE
samvdb89
88
Mar 2, 2009
Rathdrum, Idaho
My light's are pulsing at idle, and im not sure what would cause it..
Interior and exterior..
It's just during idle?
Make sure, you do have proper voltage, when car is off and while it's running. If those are good, then make sure you have correct tension on the belt, well actually if belt was/is lose, then you probably don't have correct voltage. Perhaps an alternator that is going bad. Make sure your grounds and power cables have a good connection and are not oxidizing.
Thanks you two. ziggo i appreciate the humor.
Just thought i'd see what you guys thought..
I'm having a hell of a time getting this trans back in though..
