Pulled Code
nytescion
602
Jun 25, 2007
Woodbridge, Virginia
I pulled the check engine light code and got code 24 Vehicle speed sensor.
Now I've been looking this up and can't find too much info on it. All I know is that it's behind the gauge cluster.
Can you buy this sensor in store? (searched at auto parts store with no luck) If not how do i get this fixed?
Not sure how you determined it was behind the gauge cluster as it sits in the engine bay.
http://www.dsmtuners.com/forums/art...y-electrical-connections-2.html#post151542291
It's held in by one bolt. Remove the bolt and make sure you have a good hold on to it!!! You don't want to be dropping this in the tranny, otherwise you're going to be fishing for a long time. You should be able to get one either from someone parting out their car, a junk yard, or from an OEM parts dealer.
I got it from the forums I have a 1g not a 2g. The threads said that 1g is cable driven and it attaches to a "reed switch" behind the speedometer. Is this switch replaceable or do i need a whole speedo. If so where can i find one beside ebay checked there yesterday. However i did see this
1G DSM Speedometer Drive Partsis this what i need to replace or was the rest of the forum right when they're talking about the "reed switch" behind the speedo. Please help i need this fixed asap.
kinda odd i had a code like that come up too the only thing it affects though is my speedo reads 10 miles faster. so if i am running 20 MPH it says 30MPH. found out the hard way cop pulled me over for doin 50 on the free way when i thought i was doin 60. i think i need to check the connection make sure that is plugged in all the way.
