PTU oc2 needs rewired where?
eclipsek17
138
5
Aug 1, 2004
All over, Arizona
My wiring harness was recently fried due to my dog hitting my starter switch, dont ever use a toggle switch for that, I have all my wiring back together except my PTU oc2 wire is no where to be found. Where does this wire go so I can put a new wire in. Does it go to Ecu, if so which pin is it?
I'm going to make the assumption that "PTU oc2" stands for power transistor unit open collector 2 (which goes to the 2,3 coil primary). If so then you need at least a 16 gauge wire from PTU pin 1 to the 2,3 coil's primary (one of the 3 pins in the coils plug). The original wire was blue-black.
Cool, thank you very much I couldn't figure that out. One more question the red wire coming out of the alternator plug is also not connected, where does it go? I completely forgot about that one until right now.
