headlight switch needs rewired to where?
eclipsek17
138
5
Aug 1, 2004
All over, Arizona
Was wondering if anyone knew which wires went where on the headlight switch for a 95. I have a major short issue and have already had to rewire many things and am hoping this is the last of it. I cut the wires off about a foot back from the switch but I cannot find a wiring diagram for which color of wires go where. There is also a chance the switch is burnt as well, so I need to know which wires go where to where so I can at least fix one problem then move onto the switch if needed as well. I might post again soon for another couple of wires that were burnt and shorted as well, but I am still looking to see if I can figure them out first. Unless someone can also include where all wires from fuse box plug and clips inside the car go.
Honestly that didn't help me. I looked at the area for the switch but it only tells how to test for continuity. I need to rewire the whole switch so I need to know which color of wires go where.
You could also go to a salvage yard and cut a pigtail off another car. Than just solder color to color. Find a dash wiring schematic and you should be set.
That's what I am looking for is a schematic telling me which colors go where. A pig tail isn't going to help because I need to rewire all the way to the headlights because my wiring is fried.
I don't know why you say they don't have what you need. The factory manuals tell you the color codes & they're abbreviated next to each wire on all the wiring schematics.
I think the easiest thing to do is to just go to a junk yard and grab all of the wiring from the headlights back to the switch. That way you know what the wires are and where they go. Just take a knife and a good pair of cutters with you so you can separate the loom an grab the wiring you need.
+1 The schematics have the color codes next to the wires.
#### it, I dont understand that shit. I'm just going to do the shitty way and install a toggle switch. Or find someone that will let me open there column for 2 seconds to check myself.
You will very very likely cause a fire if you wire the headlights up to a toggle switch. Sounds like it has already been on fire or close to it. They have to be ran thru a relay. Why don't you just go find a good dash harness if you are having that much trouble with a simple schematic.
