PTT twin disk and flywheel bolts
The PTT flywheel is steel. I think it's been covered in this thread, but I'd recommend test fitting the flywheel with stock bolts to make sure they don't bottom out. If they do, get shorter bolts.
My 7 bolt PTT flywheel is aluminum
6 Bolt auto bolts torqued to 100ft/lbs red loctite. No problems so far.
Cut 7 bolt bolts didnt work as the shoulder was surprisingly too big
Cut 6 bolts would work, but the auto bolts seemed like the cleanest option
