PTE turbo burning oil....
XtReMeToYz
90
Mar 21, 2004
Rochester, New York
Ha. Yea. Big surprise there I think it's because it's feeding off the filter housing though, since it has absolutely no shaft play still. What fitting do I need to make my AN line screw into the head? Is there a restrictor I should consider? Better yet, which way is the better way? I'm thinking a restrictor since it's filtered oil.
I should mention that the turbo is practically brand new and has minimal shaft play as well. I called PTE, and they recommended -3 AN line instead, but I think I'd rather use a restrictor. Is this something I can order through russel's or something? It must be a -4AN fitting on both ends, as the douche who owned the turbo before me decided to weld the NPT fitting into the center cartridge.
Thanks guys,
Shawn
Burnett03 said:
id suggest a -3an line, email me if you need help
[email protected]
I've come to the conclusion that a -3 line isn't an option since the previous owner of this turbo decided to weld the -4 fitting into the center cartridge.
I think I found a fitting today though.
Thanks,
Shawn
PTE is correct that this could be a feed issue but it can also be a return issue as well as both. I would also check for a clogged/kinked return line and make sure that the crankcase is properly ventilated.
Thanks,
Shawn
i have -3an to 4an fittings..
oldman said:
Like you have been warned and suspended for before, take this kind of stuff to pm.
was i trying to sell something to him? no? did i offer to sell anything to him? no. i said, if you will kindly look above and pull your head out of your ass.. "i have -3an to -4an fittings." Never implied i had them for sale or was going to sell them. Because im not selling them. i have one that i used on some brake fittings... Simply implying that they are produced.:rolleyes:
Wrong, saying, "There are -3an to -4an fittings" implies that they are made. Saying "I have -3an to -4an fittings" knowing your past attempts to sell shit in the forums implies to me " I will sell you some", so don't even try that bullshit reasoning.
I just had my PTE 50 trim redone by a quality rebuilder and we came to this conclusion on my end .
Problem #1 Shaft play . I had so much shaft play my bearings were shot. PTE puts what Turbo exchange calls a " floating bearing system in . The rebuilders( turbo exchange Put stationary 360 degree Bearings in
Problem 2 i know this has no bearing on whats going on w/ yours but the direct cause of my turbo going out was insuficent oiling . I did have it on the filter housing but T/E said there was no factory restrictor in the turbo so I ordered These 2 parts from Turbo time . The 1st part was the oil restrictor for a -4 an line the next is a inline filter. The reson I went w/ the inline filter was because It was told to me that there was metal shavings embedded in the bearoing. I do not know if it was from the new Motor or the turbo self destructing.
Here are some part #'s for you.
GOL-40-04AN -4AN large filter 53 dollars @ http://www.turbotime.us
TT-DSMOILFEED1 DSM oil feed for turbocharger. has inline filter to protect expensive ballbearing turbos. $144.00 also from Turbo time justr in case you need a new line.
#FCM2048 this is the reducer you may need if you wish to use your current setup .. http://www.musclemotorsports.com/1047043201.html
I am sorry I can not locate the # for the restrictor( pressure)... Hope this helps some .
