PTE 680's and stock o rings
Jiggalude
284
May 14, 2005
Lancaster, Pennsylvania
When I install my 680's can I use the stock o rings for the injectors? Or are there different ones that need to be used to fit correctly into the fuel rail?
If you're buying the injectors new, then they'll come with new seals already...if not then I'd get a new set of seals for those injectors...don't reuse the old ones...get the seals that Percision sends with those injectors
they are most likely the delphi injectors design, if they are for dsm car so they do not need a special o ring. The only thing wrong with the spray it Injectors is THEY ARE NOT MACHINED TO FIT DSM CARS.
Ia m pretty sure they are the same as the FIC injectors also, and fic has a seal kit that you can get for your injectors.
Just check stm's website:
"This set comes with VITON custom lower seals for Fuel Injector Clinic injectors which can handle more heat and boost.
Complete Seal Kit for FIC 125/6 DSM & Evo and 226 BlueMAX injectors. # SLK-125-6X4.
Complete Seal Kit for 4 injectors with Viton lower seal. Fits FIC Fuel Injectors Part# 125 or 126 sizes 550cc through 1150cc and FIC BlueMAX 1250cc through 1850cc.
These are not seal kits for OEM Injectors!"
goodluck I hope this info helped
    • george bromwell
    • pma1123
    • Sdcryan1
