FIC-- insultators and o-rings.
Lonnie gandee
213
Jan 12, 2007
LaGrange, Ohio
Ok. Sorry this may not belong in this forum...:|
I have 650FIC's. They came missing 1-insulator that goes into the head. And missing all 4 of the bigger o-rings that sit against the outside of the fuel rail to keep the injectors at a certain depth inside the rail...
IS FIC the only place that sells these insulators and orings? I'm ready to ditch these POS'S ...:mad:
just bought my upper and lower o-rings from Extremepsi.com for like $12.95 plus 7.50 for handling.
I lost one of the viton lower seals and ended up using the Home Depot Racing solution. I used two stacked o-rings for the lower. I'm sure it will fail before the other 3 viton ones, but I'm happy with the results considering I spent $0.15. I'm sure you can do the same for the top, which only requires 1 o-ring.
I Bought some 3/8 neoprean grommets from Home Depot Racing. for my siemens 750's
