Pte 5031e
ETalon95
232
Sep 11, 2004
Whitehall, Pennsylvania
How well will this 50 trim run on a stock car. Stock meaning no supporting mods just a BOV and upgraded FP intake pipe. Eventually I will get the supporting mods, but for now I need a turbo asap. The car will be tuned to fit the turbo. I'm just wondering if it is possible to run 12psi using this turbo with stock fuel, without hitting fuel cut or runing the turbo.
You can run the turbo. I wouldnt push the car hard or turn up the boost though. Although, your best bet would be to wait until you have the proper supporting mods. I had a friend run a 18G on his car w/o any negative side effects. He was only boosting 10psi and wouldnt nail the throttle though. I find it kind of hard to not drive fast every once in a while. If your like me I would definetly suggest waiting for the support.
Yes but get a logger and see where your at. I haven't heard of anyone running a turbo that size with stock a stock fuel system.
You should definatley get some sort of fuel upgrade. It might even feel slower then stock because of the lag and its effeciency range is higher then your stock turbo.
