psi and displacement
zilo900
249
4
Dec 27, 2004
Miami, Florida
Well I remember once seeing a page with a formula for however much psi of boost you run, what your displacement would be because of that. For example, xx psi it would be about the same as if the motor were a 3.8 liter engine. anyone remember or know where this is?
I think there is something like, for every pound of boost your static compression ratio goes up, maybe you just use that static compression ratio to figure out your "engine" size.
Just a thought.
I think it was a whole chart thing, maybe in excel:confused: that you could plug in air temp, psi, rpm, intercooler eficiency %, etc and it would tell you hp and some other stuff, but I just wanted to know the "calculated" engine size
Just a thought.
Static compression is not based on boost. It is based on the bore, stroke, combustion chamber size, and head/deck/HG thicknesses. To figure out your static compression, use the calculator tool here:
http://www.rbracing-rsr.com/compstaticcalc.html
You can not base calculations like that on psi alone as 15psi on one turbo is different from 15psi on another, you need airflow figures.
thanks:thumb: The sheet I was talking about also has input for airflow, I'm hopin I'll find it or remember where it was
Yeah... you run into all of those dang efficiency issues.
Turbo efficiency, Intercooler efficiency, and engine volumetric efficiency.
Then there's the Baro pressure, temperature.... and tuning.
But I hope you do find it and please post it up. I'm sure its a great tool!! :)
dude, its incredibly simple,... with our 2 liter engines (1997ccs to be exact) every atmosphere of boost you add is another 2 liters. At sea level, one atmosphere is about 14.7 psi. So at sea level, running 14.7 psi, you have roughly 4 liters. In higher altitudes where the atmosphere is less dense, you need less pressure to use the same amount of air as a 4 liter engine, AT THAT SAME ALTITUDE.
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
