prothane motor mounts
hybridkid
Dec 9, 2004
Some Where, Pennsylvania
Was wondering any one know where you can get full replacements mounts. For all 4 mount i found for the sides and the back but not the front. But is it possible to use a mount for the back in the front. Thanks jay is not in the right page please move. 92 talon awd 5 speed :talon:
The company called Prothane has a set of all 4, Slowboy sells them as does most other vendors.
If you would search, you would find your answer. Also learn how to type correctly, please WTF
The only thing your gonna find is what you already found 3 full replacement's and 1 front insert. Thats all they make for our cars.
I used that set of all 4, and one of the mounts in it is just INSERTS for your existing mount. I ended up ordering one individual mount, the same part number as one of the other full ones in the kit. I am at work right now, but I can look up that part number when I get home, if you are interested. I didn't want to use the inserts, because the original rubber in my mount was shot. So the answer is YES, you can use 2 of one of the part numbers...but I will have to check which part number that is:) I have all 4 mounts as solid prothane mounts in my 1G right now.
Ok please. Sorry about the typing sorry can't please everyone. Just trying to get a car built you know. It would have to be the same one thats in the rear. But please let me know. And i did search and couldn't find what i needed to know. I seen the one slowboy has but i wasnt a full replacement no insert. thanks jay :talon:
Ok, I looked up the part number from my last order. I bought these:
http://www.prostreetonline.com/buy/prothane_motor_mount_inserts/13-506/
It is the 13-506 Prothane Motor Mount. You can use two of these on your engine, if you don't want to use the inserts. I know, because I did:)
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
