Prosport WB logging with DSMlink?
moi1463
89
Aug 9, 2008
Jax, Florida
I know, I know, why did I get prosport. I bought it a long time ago, and now I have link, I want to know if there is a way to log the A/F ratio from the WB to simplify tuning. Im pretty new to tuning this on the street and I don't have a way to keep track of the A/F ratio other than the gauge. So I'd like to have the A/F ratio from the WB logged on DSMlink to do some tuning. I did get a lesson on tuning from one of my good friend, Ron from RS Motor, but that was on his dyno. So now, I want to start fiddling with it by street tuning. I was just wondering if there's a way to do so. The WB is installed in the rear O2 spot and I'm not really worried about simulating the narrow band.
I found out that my control box is an older version and doesn't have the output signal for logging. Having to buy one to be able to log, which they do offer, but it ends up to be just as much as all the other leading competitors out there :(. Must do more research before buying stuff.
If you are going to get a new one, get the Innovate LC-1. It's rougly the same cost of an AEM UEGO however it's response time is faster. Faster means more accurate. You will also be able to mount it in the front o2 sensor location and rid yourself of both stock front and rear sensors.
Setup for narrow band simulation in ECMLink and you are down to 1 sensor that is doing 2 functions. Great isn't it :thumb:
