AEM WB w/ DSMlink
91 TSi GP
372
4
Oct 7, 2008
Austintown, Ohio
Got a quick question...
I got an AEM Uego wideband i have it wired into my egt pin, i noticed they dont read the same so i did some searching and found thats because if you use this pin then you need a buffer circuit. fine so i did some more searching.
i found that if you tap into the baro input pin then it will be fine and read the same. can anyone confirm this? also do i tap into the wire or do i cut and run the wideband signal straight to the pin?
Picture A or B LOL
91 tsi with a MAFT
thanks
