Prosport water temp gauge
Supa Dexta
452
Sep 12, 2007
Edm,
So I wired these in long ago, but just only fired up the car and have coolant now. When I turn the key on it does it's sweep, but then never leaves the 0 after settling back. I've tried swapping the wires around incase they were polarity sensitive in some way, but I believe the coolant sensor just provides varying resistance? No luck yet, so just seeing if anyone has any tips..
Its a blue display and I think there were 4 wires on the back of it? black = ground, red = +12v, and then orange and green which I ran to the 2 wires on the sensor, was that right? I don't have any instructions for it around.. WTF
I believe the orange wire gets hooked up to change the color when the lights are on/off. Only the green wire should be going to the sensor.
I have the boxes and instructions from mine in the garage... I'll check and get back to you for sure.
K thanks guys, I'll swap it around tomorrow. And if anyone cares the sensor seems to be around 1.9k ohms when cold, and 2 or 300 ohms when warm.
