salTy
- 58
- 0
- Feb 17, 2002
Well, new injectors would be a safety precaution but the whole setup is really just a supplement to your fuel system. By injecting propane you can slip by upgrading the injectors and rely on the fuel property of the propane itself. Just remember that you are lowering the intake charge AND adding a higher octane fuel. Be sure to have a high flow pump, AFPR, and logger.
As for tank size I'd stick with a 1.5 gallon Vp. tank (which you can get from Lowes, Home depot, whatever.) And a vapor box would be nice (if you could find one large enough to house the tank). The way we setup it up was to make our own small enclosure out of aluminium and ABS plastic and ran a silicone hose to the outside of the car via the little drain plug whole underneath the wiper fluid reservoir.
... Just a few quick points I havent heard mentioned yet.
