profec b spec 2 install HELp
army26369
May 14, 2010
shinnston, West Virginia
`ok guys i recently purchased a greddy profec b spec 2 i installed it into my car yesterday all i have left to do is hook up a line to my wastegate, its external btw im thinking i can just splice into the line thats running to it but when it comes to the other vac line im completely lost it says too hook into my ic piping but i cannot find a place to do so iv been searching for a answer for 2 days now any ideas or if someone would have pics of were they hooked their lines into thanks
Does the profec come with a boost solenoid like the AVC-R? That one just routes the same way as an MBC, with one line going to a pressure source (usually j-pipe) and the other for the wastegate pressure reading.
EDIT: Here you go! Same setup like my AVC-R.
Yes that's what my unit looks like but I have the hoses coming out of the side ports bc I have a external wastegate is that wrong
Well I hooked it up ran one line to my wastegate and I hooked the other line to my cold air intake took it for a spin didn't mess w the settings yet and I was running 18lbs will this spot work or is there a different spot that I should hook into thanks
Well I drove it to work last night I tried to turn the boost down and Its still spiking past 25 lbs my car will handle the boost but I'd prefer to run 15 for daily driving I dunno if I can't splice into the vacuum hose that's running from beside my bov or if I cant tap into my intake also my valve unit is sucking air from the spot I don't have a nipple on .. normal?
