Problems with SBR T28 turbo gaskets
ILLiCliPSE
1,576
4
Jan 11, 2003
Boynton Beach, Florida
Im currently installing a t28 on my 99 GSX, and the new gaskets that I got from SBR dont exactly line up. The one Im most concerned about is the turbo to o2 housing gasket. the part of the turbo where the flapper for the wastegate is/ where the wastegate hole is, the gasket overlaps this hole. Should i dremel it out as much as i can? Will this cause a problem with exhaust flow?
Yes just Dremel it to match.
yes but the bigger exhaust hole next to it, the main exhaust hole on the gasket, is bigger than the actual hole...so i dont htink i could dremel it flush, since i would probably make one big hole. hope you understand what im tryin to say. Ill just dremel it and get it as close as possible
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
