Problems with clutch assembly?
Cool Mr Steve
553
11
Jul 18, 2004
Spanaway, Washington
Last time I posted this issue I was told to bleed the clutch fluid... Since then I got some time to further pinpoint the issue... Background: When I depress the clutch, it "clicks" about halfway down. When I let up, It clicks about 3/4 of the way up. What I recently found was that it is most audible right at the pedal assembly and that if I use my hand to depress the pedal, and pull it toward the brake pedal while depressing it, it does not click. What could possibly be in the clutch pedal assembly that could be causing this. I took a flashlight to it, but I couldn't find the source... Anyone ever had this issue?
