Problems after problems...
IamCool
204
Oct 7, 2004
milwaukee, Wisconsin
I have many problems...
1) While driving my battery voltage is always up and down. It is causeing my car to have different rpm at each stop. When i press the back window defogger, The battery voltage drops to 12.3-8. Normally it would be at 13.8. I don't know what it is?
2) When i was driving this morning and downshifted to pass this semi, after i passed the semi I shifted to neutral to let it roll because there was a car not so far ahead. Then the car's idle went to all the way down and the car died. Wehn i drive normally the idle usaully drops to only 800prm or 900rpm.
3) My autometer boost gauge shows that my car has different vaccum sometime. I mean sometimes it could be at 20 and then 15 and the 22 and so on.
Please give help insights and advice. thanks.
Now i ahve a problem shifting from 1gear to second gear. There is a little grind or i have to shift it slow to enter. Sometimes it shifts perfectly. Other times it will grind. What ciould the cause of this be?
Possibly two seperate problems.
1. Check for boost/vacumm leak.
2. Check clutch fluid level, leaks and possibly bleeding.
